Gerox píše:singl myslim T67 nebo 70 nevim presne...neni to moje auto...
T67
Boost Logic T67Ptrim turbokit
Boost Logic FuelKit, 2x Walbro, 75lbs injector, Titan fuel rail
EXEDY Twin Disk Carbon / Carbon clutch
TMS SS Clutch Line
Crower Valve Springs w-Titanium Retainers - single spring
ARP Head Studs 2JZ - U-Cut
AEM EMS Stan alone ECU
AEM 3Bar MAP sensor
FJO Wideband O2 Kit with 2-1/16'' Gauge
HKS Ignition Systems Twin Power DLI Gold & Red (New Series)
HKS Iridium sparks
HKS Super SQV Blow Off Valve
HKS 272/272 cams
Greddy strut bar
Greddy shifter knob
Greddy Full Turbo Timer
Greddy Air/Fuel Ratio Gauge - Electronic 60mm with Peak Hold & Warning
Greddy EGT Gauge - Electronic 60mm with Peak Hold & Warning
Greddy Boost Gauge - Electronic 60mm with Peak Hold & Warning
Apexi AVC-R BoostControler
Apexi GT-Spec Exhaust
Blitz V-Spec 3" FMIC
Kayaba AGX shocks
Eibach lowered progressive springs
Brembo Front Rotors
Brembo / Hawk HPS Pads
O.Z. 18" Supperleggera Rims
BFG Drag radials 275/35 R18
98" Style Front Lights
98" Style Rear Lights
Clear Front Turn Signals
HID Light Conversion
Removed Trac system
Removed EGR system
Swaped from 4sp auto -> 6sp man transmision
